Priming motor question
Brewzer67
Milwaukee, WI
So I am moving along on putting my 526" together and started to prime the oiling yesterday. I ran the drill and primed until I was able to confirm oil to one head, then rotated the engine until the second head oiled as well. The problem is I never had any oil come from the pushrod ball ends. I am using MRL/BAM's oil-thru solid roller lifters (confirmed as oil-thru) and Trend oil-thru pushrods with ball-ball ends (to go with the cup adjusters on my rockers). I have confirmed there is tons of oil leaking/coming out of the lifter bores so I know the oil is there. How long does it take to get to the cup? I am guessing it gets fed at a different time in the engine rotation cycle because of where the oil band is in the lifter. I have tried to run the drill while constantly turning the engine over by hand but then I keep overflowing the oil on the headers. Any ideas?
I would not worry about the lifters if you have "all that" now.
I am not worried about the lifters, I am worried about the pushrod end on the rocker side. Since there is no feed directly to the adjuster other than the pushrod oiling, I am worried about burning tips. If it was a cup end on the pushrod I wouldn't be as concerned because the rockers would be feeding the cup. The cam is .715 lift and spring pressure at full open is 585 pounds.
Only way I know is do what you did........and.......
Prefill the lifters by immersing them in a pan of light oil and work the plunger with a PR
Lube the rockers and PR balls before start up
Then when you start it, WATCH carefully to be sure everything starts to oil
I did the pre-soak already (for a year actually :) ) so I know they are filled. They are solid rollers so no plunger to work. The cups are filled with an oil soluble assembly grease so that is done already. I can take the wait and see approach but would rather know ahead of time. Custom 7/16" pushrods aren't cheap so I'd rather not smoke a set if I can avoid it.
Pushrods don't oil until the engine is running, so a little assembly grease in the cups and good to go.
the grease is not allowing the oil to come through. get rid of it!!!! you will burn pushrods for sure with it in there!! I had a guy burned up 3 sets pushrods with grease in cups. told him to use oil, no problem after that. the grease cannot get out, stays and cooks!!
I will defer to Mike at B3 Racing on that one as he assembled the rocker setup. What say you Mike, do I need to remove the assembly lube you used?
If I was doing another stroker, I`d cut a small groove about .020 to .030 in the no. 4 cam journal. Will have a small amount of full time oiling to the valve train. Would be way better than drilling the oil passages in the gallery and then having to regulate it down, like I did. .
