63dartman
How is this done? Do you pull out the distributor gear and make or buy a shaft to drive the oil pump or do you leave the gear in and drive the entire assembly? Thanks.
And.........
You have to rotate the crank to get the cam oil holes lined up, otherwise you won't get oil to the lifters
Not quite. You do have to rotate the engine to line up the holes in the cam. But those holes feed the rocker shafts on each head. The lifters get oil from the passage that runs up from the oil pump tothe right side galley, which in turn feeds the main bearings, and the left lifter galley .
I took an old pushrod and welded it to the shaft of an old oil pump drive... Not perfect, but free and it works perfectly.
haha i was trying to think of the proper term and couldn't come up with it in my stupid nogan
dist gear.. oil drive.. nope you got it (intermediate shaft)
