I saw it, but it's impossible to tell. Remove ONE if you can. Put it on a flat surface and put a pushrod into the cup and see if you can press down on the plunger (if it has one) and bleed the oil out. Then, if the plunger is spring loaded, and returns back to the top after you push it down, it's hydraulic. If you can shake the lifter and it rattles from the plunger rattling freely, it's solid......and nice solid lifters, too. Oil metering like I described above. They may just be a solid hunk of metal, which is fine too.
