Demon 408
The system includes all new brakes parts: calipers, wheel cylinders, lines and proportioning valve. Brakes are all maunal (no booster), front brakes are 73-76 A Body disc with 10" rear drum. Calipers are mounted in front with bleeder at the top (stock location). The proportioning valve is from Inline Tube (part number BLK250). The master is a newer Mopar style that I bought from Rick E'berg, it's a cast iron model with plastic body and two separate plastic caps. I reused the factory manual brake rod that was on the car. I'm guessing it is/was correct for a manual drum brake car. I'm using Valvoline synthetic DOT 3/4 fluid.
Bench bled the master cylinder. I bled it until the there was no air bubbles in the clear plastic lines. I re-bled the master on the car, it looked good. After that I conected the hard lines. I have not allowed the master to run dry at any time. I bled the front brakes and got a "rock hard" pedal at about the 1/2 way point on the pedal travel.
I tried bleeding the rear brakes and there was no fluild flow to the rear wheel cylinders. So I removed the brake line at the rear end connection. The pedal stayed firm with line removed, and still no fluid flow. So I connected the bleeder bottle directly to the front of the master cylinder and got fluid flow.
So that leaves the long line from the front to the back of the car, but it's new and I didn't find any kinks, and lastly the proportioning valve. I read my FSM and it said that on cars with vertically installed proportioning valves you need to "fool" the valve to make it act like the front has a leak so the valve will switch and you can bleed the rear. I opened the front and rear bleeders on the right side of the car. The front bled fine, but again no fluid flow to the rear.
I don't think the rod is a problem because I'm able to pump fluid through the master when I had the front master line (rear bakes) emptying into a bottle.
Ideas?
