rkjjeep
Anyone try one of these? I have to move the column and coupler and remove the pin to change the lower column seal and this looks easier than the new seal and metal cover.
Where do you find information on that part?Anyone try one of these? I have to move the column and coupler and remove the pin to change the lower column seal and this looks easier than the new seal and metal cover.View attachment 1715379608
Found it here, but I haven't tried it.Where do you find information on that part?
You put it on without the gasket and metal cover, right?Yes I have one on mine. It’s great!
ANy more pictures of the other side?Anyone try one of these? I have to move the column and coupler and remove the pin to change the lower column seal and this looks easier than the new seal and metal cover.View attachment 1715379608
.....Getting the metal covers crimped sucks!
Plus the seller in the link says they are stainless steel.Not sure if a coat hanger would do it.Mines is made from some type of spring steel and they are only $10 so no savings to be had by making your own.
Don't try and take the pin out..disassemble your column shaft.It's just a C ring and the shaft will slide out.
..that wire retainer can be made at home in a few minutes with some 11 gauge rod or a coat hanger with a bit of careful bending.
