ProForged LCA bushing install question
Suspension, Steering and Chassis
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    522
    125
    May 18, 2019
    Indio California
    Local Time:
    1:14 PM
    I bought a set of pro forged LCA bushings and had a question on installing the pin. Does the pin get pressed into the inner sleeve to the point where it would bottom out on the sleeve due to the ridge on the pin, and continue to be pressed where the until the bigger ridge is flush on the exposed bushing like shown in the last picture? Thanks 117921321_3221440941307175_1589156092042406562_n.jpg 118272316_3147933908659728_4728857011773715825_n.jpg 118396319_758000541706359_5879794235421000295_n.jpg
  2. cudascott
    cudascott Now I have a Hemi
    1,879
    782
    Jan 11, 2012
    TN
    Local Time:
    4:14 PM
    The bushing presses on the pin up to the first step on the pin oriented like your last pic.
    • Thanks! Thanks! x 1
    • C2ndLTpigeon
      522
      125
      May 18, 2019
      Indio California
      Local Time:
      1:14 PM
      The bushings I have in the picture already have an outer metal sleeve on them, there would be no way you could press it onto an old sleeve
    • cudascott
      1,879
      782
      Jan 11, 2012
      TN
      Local Time:
      4:14 PM
      I seen that after I posted I changed my reply
      • Agree Agree x 1
      • C2ndLTpigeon
        522
        125
        May 18, 2019
        Indio California
        Local Time:
        1:14 PM
        I posted another pic of how I think it goes. Pin gets pressed into cent sleeve and when its all the way to the ridge it gets pushed in further stooping at the big ridge, I take it since stock bushings did not have that extra martial out of the casing.
        Would be nice if the bushings told you haw to install them. 117972180_595590481121181_2604653507364251196_n.jpg
      • cudascott
        1,879
        782
        Jan 11, 2012
        TN
        Local Time:
        4:14 PM
        I think your correct just makes sense to me as well.
        I have never used the poly ones so I can’t say for sure but if not done the way you state then the relation of the lower control arm to the K member would be wrong.
      • Jim Lusk
        Jim Lusk Well-Known Member
        4,917
        1235
        Mar 8, 2006
        Fresno, CA
        Local Time:
        1:14 PM
        Never used those, but yes, it looks like they should be pressed all the way. Not sure I really like the setup, though.
        • Agree Agree x 1
        • kursplat
          kursplat FABO Gold Member FABO Gold Member
          3,818
          2732
          Aug 24, 2010
          so cal
          Local Time:
          1:14 PM
          if the bushing is the same length as stock + the pin is stock + the pin needs to be in the stock position = the pin needs to be installed just like the stock ones.
        • C2ndLTpigeon
          522
          125
          May 18, 2019
          Indio California
          Local Time:
          1:14 PM
          And the way I imagined it seems to put the pin in the stock position just wanted to double check.
          I don't see why these bushings would be a worse set up, hopefully they will last better than stock, either way suspension upgrade will happen down the line.
        • cudascott
          1,879
          782
          Jan 11, 2012
          TN
          Local Time:
          4:14 PM
          The one thing I’m not sure about on these is how you press them into the lower control arm without putting
          stress on the bushing material.
        • 4spdragtop
          4spdragtop CONGRATS NORTH AMERICA!
          31,827
          12360
          Aug 28, 2009
          Wasting time here
          Local Time:
          3:14 PM
          No help from me, but can you update this thread as I'm interested in the Proforged stuff.
          • Agree Agree x 1
          • C2ndLTpigeon
            522
            125
            May 18, 2019
            Indio California
            Local Time:
            1:14 PM
            I will try to do that when I reinstall the arms.
            • kursplat
              3,818
              2732
              Aug 24, 2010
              so cal
              Local Time:
              1:14 PM
              • Like Like x 2
              • crackedback
                crackedback FABO Gold Member FABO Gold Member
                18,916
                3359
                Aug 7, 2005
                92201
                Local Time:
                1:14 PM
                Put a socket that fits snug inside the bushing when you press the pin in. You need to support the sleeve or you will destroy the bushing.
                • BergmanAutoCraft
                  BergmanAutoCraft FABO Vendor FABO Vendor
                  197
                  165
                  Feb 18, 2013
                  Long Island, NY
                  Local Time:
                  4:14 PM
                  Delrin is harder than urethane and due to its self lubricating properties, its is silent and lasts forever. My bushing don't need the inner OR outer shells if used with my pins.
                  • Like Like x 1
