72ScampTramp
Scamp Tramp
What is the proper way to adjust rockers in an adjustable setup? My book doesnt show it and the videos on you tube are hyd cams?
thanks Rick thats the one i seen awhile ago but couldnt find it today. After setting the lash at .014 per my cam card Im able to still spin the pushrods in the closed position is that normal?
X2 what 67 dart 273 said. You can't use the 8 position method on cams with a lot of overlap.
EOIC
Turn engine until the EXHAUST valve starts to OPEN, set that intake
Turn engine until the INTAKE opens and nearly CLOSES, and adjust that exhaust
This works on anything from a 1 cylinder B&S to a P&W radial
x2 best for me,quicker too...EOIC
Tony,any experience,with Voodoo solids?.
