proportioning valve question
trudysduster
Corinth, Ky.
I have a 73 Dart Sport with disc in the front and drum in the back. Do these usually go bad if a car has sat for a long time. I am running all new lines from front to back and I was thinking of this as I replace the lines. now would be the time to do it. What is the correct name for this thing. Thanks, Bill
Proportioning valve or PV, usually. I believe that on a 73 with factory disks, these are built into the metering block -- that is, the brass junction mounted below the master cylinder that the brake lines from the master cylinder route into, and that also includes the "safety switch" that activates the brake warning light. So there is no way to adjust the "proportioning", and no reason to expect it to go bad.
Earlier cars (my 67 Barracuda) had a separate, adjustable proportioning valve inline with the rear brake line. These could potentially get stuck, but there really wasn't any reason to adjust them, anyway. The "proportioning" referred to in the name isn't referring to adjustability -- it's referring to the purpose of the device, which is to slow down the rate of application of the rear drum brakes, so they do not lock up before the front disk brakes. This is needed because drum brakes are designed to have a non-linear response -- as the shoes make contact with the drum, they pull themselves tighter, increasing the amount of braking proportional to the amount of pedal effort used. Disk brakes have a linear response (more pressure equals proportionally more braking). The PV steps down the rate of pressure increase to the drum brakes.
If it has been open for a time the brake fluid could draw moisture into it and ruin it.
Does "these" mean the calipers and wheel cylinders? Since replacing the brake tubing (usually don't need to), best to replace the rubber hoses and replace or rebuild the drum wheel cylinders, since real cheap. Usually the rubber is fine and leaks come from rusted cylinder bores. Glycol brake fluid (DOT 3, 4, 5.1) should be changed every few years, especially where you live. If you use DOT 5 (silicone), it doesn't need changing, plus won't remove your paint.
well I am talking about the brass block that sits under the master cylinder that the lines go into from the master cylinder that branch off to each brake. it also has the brake light switch on it. isnt that what is called the proportioning valve on a 73 Dart Sport. What ever it is called, now would be the time to replace it for me. After looking at the guy who posted a little earlier, I guess that is called a distribution box. The pic he has is what I have.Thanks
yes that block goes bad i am dealng with 1 now
i want to buy a new 1
