Thunder
I started removing unneeded accessories from a 440 I am putting in my Dart Sport. The motor was cut from the vehicle { unknown } with a torch. They cut the K frame, steering column, and everything else. After removing the steering box, power steering pump, and A C compressor I realized that the pulley for the water pump is run off the power steering pump. My question is, does Dodge make a three groove pulley for the water pump or would I be better off going with an electric pump?
The motor is a '73. The #s on the pad are 4 T 440 E if that helps any.
Thanks in advance.:coffee2:
I am pulling a decent running /6 w 904 out if anyone might be interested.
