pulley
highflyer
oakley ,cal
i need the double crank pulley for 73 duster 360..verting to p/s and the triple pulleys i have wont work..too large in dia..need ruffly 6.5 dia...let me know if you are selling ..pls..j
I have a triple and a double crank pulley.
6.5" from inner v groove to groove.
The double has a smaller pulley diameter on the side closest to the engine...about 1/2" smaller.
The triple has all pulleys with same diameter.
Let me know if you wants some pics.
Thanks,
Mop
i have two triples and they both are about 7 inches major dia...they rub the w/p pulley..im in need of a pulley for alt and p/s...im gonna get the pump mounted today and see whats up...ill get back to you..tx..j
any body have a double pulley they want to get rid of...i have a water pump pulley and need the double to go with it...inner drives the alt and outer drives the p/s pulley...any body have one they want to sell..please pm me if you do thanks ..j
Do you need one with the one hole offset or all holes centered? You have to look at you harmonic balancer...I have one with centered holes
