andrew3408
1969 Plymouth valiant
In mechanical-lifter (solid & roller) cams slight adjustment can be made to Overlap & Total Duration by minor changes in valve lash. Non-standard lash settings are recommended for test purposes. Crane suggests +.004" & -.008" (adjusted from manufacturer's suggested hot settings) as maximum limits for continuous use.( well this is from the cam data chart write up)
