push rods
earthmover
in the tire smoke
nc
guys what your thoughts on push rods should I thought about the comp cam mag. ones then I thought about getting some made....I have 1 to go by with almost 1 comp. tread showing but dont know if thats good enough or not....if I need to have some made whos gets the :cheers: from you guys and whats the contact info...almost ready to set motor down in the car just need push rods.... also what would you guys run as far as plugs I have used auto 63and 65..I plan run 110 fuel and what should I set the timing at once started dist.. locked out so whatever total.....thanks
you seem close to getting the engine in the car, sorry but i don't know anything about pushrods
yea thanks my son stays on me and when I out in the shop here he come to turn a bolt or 2 plan to let him drive a little this time out 16yrs old let old dad look and work on the old girl....:cheers:
I use Smith brothers for pushrods: 1-800-367-1533 or www.pushrods.net
They will need an accurate length. Comp Cams has a variety of length checker pushrods, stock small block is around 7.500.
Solid lifter/adjustable rocker pushrods tend to be around 1.50" and hydraulic lifters with adj. rockers tend to be around 7.23". Comp Cams has a 7.31" version but they don't always end up correct.
I've run pushrods with 1-2 threads recessed as well as 1-2 threads showing. 1-2 showing is about right, as long as the lash or preload is correct.
I just want to post this pic of the rockers and push rod 1has 1 tread and the other has about 3 treads showing
try this again
ha I did it thanks for your help Dreno I learned something new today without beating on the puter...now you guys will get tired of pic from me....hahaha:munky2:
