72Dart6pack
Harder Better Faster Stronger.
Just as a reference as the type of work I do. My 408 6 Pack.
Does ARP sell Allen head timing gear bolts.I used allen heads, and still had to cut the heads down some-------
Don`t know, I used regular black 3/8' allen heads from a anywhere. Most are grade 8 around here. As long as possible too ! Just get the heads shorter than the button.Does ARP sell Allen head timing gear bolts.
Ok, thank you ..we have a couple of places I think I can get them.Don`t know, I used regular black 3/8' allen heads from a anywhere. Most are grade 8 around here. As long as possible too ! Just get the heads shorter than the button.
He is working on a big block which requires a cam button.
If you don't mind, would you show us some pics as you do the assembly. That would be a good "how to" on here.He is working on a big block which requires a cam button.
No can do. Sorry.If you don't mind, would you show us some pics as you do the assembly. That would be a good "how to" on here.
Appreciate the advice and info. anywayNo can do. Sorry.
Question? How many current factory roller cam motors have cam buttons?
