racerdude5
Okay so I got the k member on and everything is lining up except for the passenger side motor mount. I have the bracket with the 3 bolt holes on the passenger side and it won't fit no matter what. On the drivers side I'm using the four bolt bracket mounted on the forward side of the holes in the block. What's going on here? I need some help. I'm so close to finally finishing then this came up. How many different types of brackets are there for A-Bodies with small blocks? 62-66 67-72 Driver's Passenger's etc? How are they orientated on the block? Front side of mounting holes or back side? Thanks!
