[WANTED] Quarter window track wanted
Texas69dart340
Temple Texas
Rating - 0%
0   0   0
Need the driver side and passenger side window track. I need a set that doesn’t have the window mounting bolts broke off. Picture of what I need.
I had one in my 69 Dart that had both bolts broken off. I just drilled & retapped the holes. Can't you just do that?
I had same issue . I drilled the broken bolts out and used a self tapping screw one size larger . Or use a tap set ....
