Question about Carter 2bbl carb numbers
1968 Dart 270
Usa
What is the difference if any between a Carter 2bbl 4417s (1968 273 v8 at) and a 4421s (1968 318 v8 at) and a 4608s (1969 318 v8 at) they all appear to be physically exactly the same. I'm just curious if functionally there is a difference between the 4417s which is for a 273v8 and the others that are for 318 engines
It is most likely the calibration... Different size jets and squirters....
They all will work on your engine...
The step-up rods and the float needle and seat are different, probably jets.....maybe other things as well.
