Question about grill and turn signal matches???
USMC1968
Can anyone help me out by letting me know what all is interchangable between 67-69 Barracuda front end parts? Mainly turn signals, grill inserts, bezels, taillights........things of that nature? I've found a few and want to know if they will work or not. I don't want to get them and have some "mut of a car" A thank you in advance to anyone who can enlighten me on the subject.
The outer surrounds and headlights bezels on 67 and 68 are nearly the same.
From there, everything else is different.
My grilles are all 67 except they have 68 ribbed plastic inserts. Not an easy task by any standard.
I thought the turn signal bezels and lenses were the same between 67 and 68 also, no??? 69 stuff is completely different. Geof
67 and 68 are different turn signal bezels and lenses.
To use a 67 grille surround in a 68 you have to change the wide center support for two 68 center support. The inner most grille surround support is the same 67 to 68. The supports are riveted to the surround. Not pot riveted (but that will function).
Thanks for the input guys, probably just saved me a pointless purchase. I appreciate it.
