Question about installing super stock springs
prochamp98
Member
508 North Villa Grove Il
Got a ? about installing super stock springs. I installed a 3" spring relocation kit from mancini. The shackle angle is different on the left side from the right side. Is this normal since the springs are different from left to right. Will it work ok like this. When I installed the relocation kit I kept my measurements the same on both sides. I was told they need to be the same when installing super stock springs.
THe right side spring is stiffer. So I'm sure they will be a little different on the rear angles. Give them some time as they will settle.
The preload on them is different each side so the different shackle angles is normal and how they are supposed to be.
Thanks for the replies. I was thinking about going with the sliders if this was going to be a problem. This car will be on the dragstrip only, so I have some options.
I have 002 003 springs. My front and rear locations are perfectly square on both cars. The shackle angle is different from side to side. On excelleration they will wrap even and straighten out because of the torque going to the right rear. Your good as long as you measured from the lower A-arm holes in the K back and the measurements are the same from the front spring holes to the shackle holes. This squares the front up with the back and prevents the car from trying to spin around when heating the tires. and also pulling to one side on excelleration. Some guys never installed them correctly so they don't Know. nqkjw is correct with his answer. I saw conflicting answers so I replied with mine.
One of the reasons guys go with Fourlinks or latters . They can adjust for this. with leafs you have to be right the first time. I was at Carlise and watched the burnout contest. alot of the know it all's couldn't keep their cars straight at all. But most were done for show not for go.
Take your time and do it right. My one car the right rear had to get moved back 3/8's inch. I can sit at one spot now shift to second and ithe car never moves to the side ..
Notice in the pics of the car on the lift the left rear hangs lower . even with the stablizer bar with the same SS springs. If you sit the car down it tilts the other way. This is because the right rear is alot stiffer. I crank my left front bar up two turns and put the front stabilizer link back on if I am not racing the car and going to cruises. (second last pic) Otherwise the car leans to the left. Notice on the (last pic) how much lower the shock plate is but it still sits level. If you take the turns out of the left front it leans almost that much. Just my input but what do I know compared to the specialists.
To properly set these up for forward bite. Set the car on a level floor and jack the car under the center of the rear. This creates a tripod and the rear springs are not trying to change the front hieght. Level and set the ride hieght on the front as per the manual not off the frame or body but with a measurement from the lower a-arm pin and the bottom of the lower ball joint. subtract the difference and you have your ride hieght . They should be the same if your ball joints are from the same manufacture. Now once you let your car down without the stabilizer hooked up it will change the front measurements and lean. Turn the left bar adjuster in raising up the left front counting the turns until the car is level. When wanting to use the effects and purpose of the SS springs take out that number of turns. But the car will lean. Works for me every time and my car goes straight as an arrow .
^I thought the right side should sit higher with SS springs?
(can't picture with my Duster how it sits, it has new SS springs under it)
edit- reread what you put "Otherwise the car leans to the left"-I misread it the first time...
Remember...any time power is put to the rear wheels, the driver side tire is being pushed into the pavement, while the passenger side is trying to go up into the wheelwell, and come off the ground. The passenger side being higher at static ride height would be correct, and put them near even when under hard acceleration.
They need to have the correct angle and should be the same on both sides. What you got is a car with the factory tolerances off on one side, or both. Need to fix it.
http://www.forabodiesonly.com/mopar/showthread.php?t=10528&highlight=shackle+angle
Most guys put a block behind either the shackle or hanger mount to space it back to where it needs to be.
The relo would of been a good time to fix it.
nope... being the same side to side and having the correct angle are two different things... with different spring arches and rates there gonna be a little different... as long as the hole in the front mount and rear mount are 53 (i think it was 53) inches then your golden...
My S/S springs, the rear shackle on the passerger side is moved about 1" to have the shackle at the angel it should have because of the different arch in the S/S springs 002 and 003. My car also sits about 1/2-1" higher on the passenger side.
:-k Sorry should have been more clear. I was talking about the shackle angle.
