dwire67
Long story short I am working on a guys car and he works with my wife @ her job. We worked out a deal where I would check his 1966 GTO clone out and get it running for him again since it has been sitting for 10 years. The car has tri-power and the last time he drove it he said it leaked gas bad and would barely run ,along with almost went on fire. I start tearing into it and the tri-power carbs are junk, throttle plates are all pitted & rusted . I talk him into switching it over to a single 4 barrel and electronic ignition for easy of driving.
Then I find the raditor is junk rotted out, freeze out plugs are rotted and where leaking. I tell him the engine has to come out to fix the freeze plugs. So I drain the oil and it stinks bad and looks likes black water! I pull the trans and the clutch assy. and fly wheel are junk, pull the oil pan and check 2 &3 mains the bearings are wiped out and it has broken valve spring retainer. The brake lines are rusted and the rubber lines are junk.
Here is the problem he does not want to fix it right after I told him he looking @ 5 grand to fix it right, he wants it back running as-is. he says it ran before it was parked and should be fine and he wants to drive people around in it?
I am wrong for refusing to do as he asked? I told him he it gets fixed right or come get it as-IS!
