Rat Patrol
Probably not the best place for me to post this - but maybe Joe Dokes or someone will know...
I want to test my aftermarket Ampmeter in isolation using a multi meter
Is there any way to do it using ohms resistance measurment to see if its reading current as well as just passing voltage?
If not...
......can I connect my multi meter in series with the ampmeter - attaching a test wire from the BAT post on the Alt, to the ampmeter, from the ampmeter to the multi meter then from the multi meter to the start relay post?
If not...
