My bad was thinking wrong here is the way you have got to do it
If you can, fill the oil filter and install, remove all the spark plugs and remove the coil wire and ground it (or disconnect the coil pack if the engine has distributor-less ignition). Also, if the vehicle is fuel injected, remove the fuel pump relay to prevent flooding. Crank the engine for 30 seconds, then wait 5 minutes for the starter to cool off. Repeat this procedure until the oil light goes out or the gauge rises (whichever you have). If you didn't prime the pump, this will take a while. Don't be impatient waiting for the starter to cool between cranking sessions, or you'll be replacing the starter also! Once you have oil pressure, install the spark plugs, enable the fuel and ignition systems and start it up! Good Luck to you!!
