Just finished my install of the wilwood kit on my 8.8. I thought I had ordered a kit to run the calipers in front of the axle, but maybe not. Regardless that's how I set it up, and now the parking brake bracket faces the rear. I'm assuming with longer cables I could just run the cables to the backside of the axle and connect them, but that seems sloppy.
It seems like this kit would work to basically flip the parking brake hook and cable hole:
Wizard Brackets - Reverse TJ Style Parking Brake Cables
Thoughts on the two solutions?
Edit, now that I think about it, running the cables to the back can't work as pulling the brake will just take up slack in the cable, duh.
