R1A 48 degree block NOT LIGHTENED and UGL Cam
spdge70
Rating - 0%
0   0   0
48 Degree R1A block. Has motor mounts and oil filter threads. UGL cam. Both are new, block on factory pallet, never machined. I might have the cam bearings too, I need to look.
$2000.00 OBO
Going to put it on ebay tomorrow. Here are some pictures, I was hoping that someone here would pick it up. $1500.00
What part # on Block?
Is it a 9.20 deck with 48 degree lifter angle?
9.20" 59 R3, there was a large production run of them machined with wrong cam tunnel. Easy to ID, just look @ #5 cam bearing bore, if it's the same size as the #1 bore, then it has a 48 degree cam tunnel in it.
Not to rain on your parade , but if this is what is then it takes a special cam and if LSM will make you one they cost about $800 just for the camshaft
Part Number is P4532435 This is a 48 degree 9.200 deck. Cam Races are uniform in size.
Thanks
