Radiator hoses for Early Truck 5.7 swap
mshred
The Green Manalishi
Trying to finish off some swap parts for my 5.7 into my 71 scamp, and rad hoses have me scratching my head. As you can see from the pics, the rad is a Champion 3 core with the factory inlet and outlet locations, and I have an 04 truck timing cover on the engine, which has upper hose on driver side and lower hose on passenger side. I have had some suggestions on facebook for hoses, but none have have worked yet, or are even close with trimming.
Wondering what others here have used. Getting desperate here, as I want to get the top hose sorted so I can continue to fab my intake charge pipe setup coming from the intercooler knowing that things are where they are.
Thanks
DELETED
Sorry I missed the side outlet thermostat cover.
The front accessory support looked just like the 96 JGC.
I use the same cover with a similar Be Cool radiator (same one I used for the 408). I fabbed my own intake tube and use bendable metal tubing top and bottom. I did have to get a reducer hose for the large water pump inlet.
I have been thinking of going the flexible house route. Whose product did you use? I checked out some of the options on the summit website, and a lot of them say it looks nice but does not perform well in terms of longevity/durability, especially in regards to the adapters and clamps. What has your experience been like?
I dont like using those hoses but I do like the idea of using it as a gauge
Bend it to shape, take it in to a shop and see if you can't match it up
They are Summit, The rubber inlet adapter is Spectre. Longevity isn't an issue. I replaced the OE clamps with sturdier pieces (Ideal) as the will strip out. If you are going rubber, the hard part is the lower hose. There are no parts stores here around I can rummage through, so this worked well for me. I know it reminds folks of the infamous universal rubber hoses, but much like them it works.
I've heard of guys bending a coat hanger in the shape you need and taking it to the parts store and seeing if you can find a radiator hose hanging that matches.
Here is a slant 6 radiator hose that may have the bends that you need for the upper hose.
Looks like a standard lower hose for a '76 D100 truck (small block) will work for your lower hose.
I bent a coat a metal rod I had and used that then bought about 8 hoses that were close and returned the 6 I didn’t use. Had to trim them a bit. The Autozone guys let me in the back to sort through them. Just tell them the year model and the engine they will give up pretty quickly
Bumping this thread back up as I have still yet to find a lower hose that works with the truck style cover and water pump (pre eagle) and my passenger side outlet on the rad. I did figure out the top, used a Holley flexible adapter and a dayco hose.
Anyone have a SURE part number that works? Parts stores here aren't letting me in the back with the coat hanger I bent up...I've tried multiple, and it's a no from all of them with an insistence on year make and model
I’m not sure if the year matters but what year is your motor. I can did out the part number for mine it’s a 2004 5.7. But your radiator outlet may be different. I’ll see what I got.
That would be helpful! Have a pic of your engine bay? It's a 2007 engine, but it has a timing cover off of I believe a 2004 ram to work with the truck procharger bracket in running. I could be wrong but I think all the early 5.7 truck timing covers were the same, then keep and car were different...
Should be the same. I’ll did through the archives and find the hose. I had to cut some of the hoes off. I’ll get back to you tomorrow
I can not find a number on this hose and all my receipts are have faded. Tell the auto parts store you will buy all the hoses they have in stock and you will return all but one if they can’t let you look. I bet they change their mind. Sorry couldn’t help.
Maybe this week will be slow at work I’ll just take it off and go to store for you. What is the lower radiator O.D. Port on your radiator
How far is the center from your frame rail.
I can not find a number on this hose and all my receipts are have faded. Tell the auto parts store you will buy all the hoses they have in stock and you will return all but one if they can’t let you look. I bet they change their mind. Sorry couldn’t help. View attachment 1716493092View attachment 1716493092
I appreciate you taking the time to look man! And that's a very kind offer on your part. Hopefully someone else chimes in that might have a part number. I know once I figure it out im writing the hose number down somewhere so that if I need to replace it I'm not doing this dance all over again.
I believe the lower outlet on the rad has an o.d. of 1.5" or 1.75"? I will have to double check and measure, as well as that distance to the center of the cross member. It's a Champion 3 core rad that I had used with my smallblock LA.
