Mr.FT
Can someone recommend an overflow bottle for my 72 demon 340? I know it did not come with one but didn't know if any others would fit without looking too far out of place.
Thanks
Thanks
I'm not convinced that damn thing is worth two cents. It doesn't seem to be "recovery," only overflow?? Which means you have to keep draining it
All you have to do is attach a hose inside to the inlet tube, that's what I did with mine, it works like a champ. Mine has a petcock on the bottom to drain it, now I don't have to use it.
But you're right, it is only a puke tank.
You could also use the bottom valve for the inlet, I guess.
The fact that it can be easily "fixed" is a help. I did not know that. You could also use the bottom valve for the inlet, I guess.
Demon408, does it come with mounting brackets?
