Radiator recommendations?
69Nopar
New Member
Florida
Can anyone recommend a good and fairly priced radiator for 69 Dart with soon to be installed 440 and 727 Trans? I may or may not reinstall AC later.
Thanks
Looks good if you want to do a custom setup etc but what about a good replacement that will bolt in to the existing holes and look original?
Need more info. Big blocks had water pumps w/ inlets on both L & R, so depends on yours. Big block Darts were very rare so you will likely have to figure out hoses that fit, but search the Big-block forum.
