Radiator / waterpump question
smythge
65 with a BIG BLOCK
I have silly question in my 65 Dart the current water pump and radiator are on the drivers side. (Which blocks the timing tab, and sound like the bearings are going, also has a small bypass hose.) I would like to swith the water pump to one that exits on the passenger side. If I do this do I have to replace the radiator, or can I just get a longer radiator hose?
I take it you have a small block? If so,get a complete timing cover and pump from a donor car and order the water pump for that car.As for the rad,you build a cross over tube from newly bent exhaust tubing for now and then later have a rad shop relocate the outlet,just some ideas,mrmopartech
Yes I have a 318, it was an original 273, when the motor was replaced they used the old waterpump.
