Radiator
Well, the only radiator available in 64 was a 19", so I highly doubt that the opening is sized for the 66's 22" radiator! However, you should be able to work it in there with some skills, or replace the radiator support if you're not into cutting the opening!! Geof
I ordered most of my parts for a 64 Barracuda. Only issues where taillight gaskets and door panels. The owner did not correct me on calling it a 64 till after the door panels. The radiator will fit if both were v8.
66 core is 22 wide x22 tall, not measured at bolt mounting. Well mine is.
