Railroad tracks
inkjunkie
Why 4 feet 8.5 inches is Very Important
Fascinating Stuff . . .
Railroad Tracks?
The U.S. Standard railroad gauge (distance between the rails) is 4 feet, 8.5 inches.
That's an exceedingly odd number.
Why was that gauge used?
Because that's the way they built them in England,
and English expatriates designed the U.S. Railroads.
Why did the English build them like that?
Because the first rail lines were built by the same people who built the pre-railroad tramways, and that's the gauge they used.
Why did 'they' use that gauge then?
Because the people who built the tramways used the same jigs and tools that they had used
for building wagons, which used that wheel spacing.
Why did the wagons have that particular Odd wheel spacing?
Well, if they tried to use any other spacing, the wagon wheels would break on some of the old, long distance roads in England, because that's the spacing of the wheel ruts.
So, who built those old rutted roads?
Imperial Rome built the first long distance roads in Europe (including England) for their legions. Those roads have been used ever since.
And the ruts in the roads?
Roman war chariots formed the initial ruts, which everyone else had to match
for fear of destroying their wagon wheels.
Since the chariots were made for Imperial Rome,
they were all alike in the matter of wheel spacing.
Therefore, the United States standard railroad gauge of 4 feet, 8.5 inches
is derived from the original specifications for an Imperial Roman war chariot.
In other words, bureaucracies live forever.
So the next time you are handed a specification, procedure, or process, and wonder,
'What horse's *** came up with this?', you may be exactly right.
Imperial Roman army chariots were made just wide enough
to accommodate the rear ends of two war horses.
Now, the twist to the story:
When you see a Space Shuttle sitting on its launch pad,
you will notice that there are two big booster rockets attached to the sides of the main fuel tank. These are solid rocket boosters, or SRBs.
The SRBs are made by Thiokol at their factory in Utah.
The engineers who designed the SRBs would have preferred to make them a bit larger,
but the SRBs had to be shipped by train from the factory to the launch site.
The railroad line from the factory happens to run through a tunnel in the mountains
and the SRBs had to fit through that tunnel.
The tunnel is slightly wider than the railroad track, and the railroad track, as you now know,
is about as wide as two horses' behinds.
So, a major Space Shuttle design feature
of what is arguably the world's most advanced transportation system
was determined over two thousand years ago by the width of a horse's ***.
And you thought being a horse's *** wasn't important!
Now you know, Horses' Asses control almost everything.
Explains a whole lot of stuff, doesn't it?
.............which brings us to the Panama Canal.........
I saw a show showing where they are going to build a new canal, further north then the Panama canal.
Here's one I read a long time ago in EDN Magazine - sounds a bit 'apochryphal', but...
Llama alert!
We engineers are so good at solving problems that we sometimes forget to ask if the problem has been posed correctly; we just solve it. Yet questioning the rationale behind product specifications can avoid a lot of pointless effort.
Consider the US Army's llamas. In the early 1940s, so the story goes, the Army wanted a dependable supply of llama dung, as required by specifications for treating the leather used in airplane seats. Submarine attacks made shipping from South America unreliable, so the Army attempted to establish a herd of llamas in New Jersey.
Only after the attempt failed did anyone question the specification. Subsequent research revealed that the US Army had copied a British Army specification dating back to Great Britain's era of colonial expansion. The original specification applied to saddle leather.Great Britain's pressing need for cavalry to patrol its many colonies meant bring together raw recruits, untrained horses, and new saddles. The leather smell made the horses skittish and unmanageable. Treating the saddle leather with llama dung imparted an odor that calmed the horses. The treatment, therefore, became part of the leather's specification, which remained unchanged for a century.
So, on your next project, make sure you know the reasoning behind the specs. If you hear "We’ve always done it that way," watch out for llama dung.
So what DO ya use instead of llama crap?
