[WANTED] Rally Dash Frame
I might be able to get you one. Won't exactly be cheap, though. I'll check with my buddy who has one.
Are you looking for the frame portion of the cluster? If its the same as '68 Barracuda with rallye dash I have one. Would you like a picture?
In 1970, the key changed to the column, so any frame before 70 has an embossed recess for the key switch.
I would also like to point out that the key switch embossment is different between 67-68-69, all 3 years have their own key switch design. The heater control mounting is also different between 67 and 68-9, as well as the glovebox door latch and hinge.
