[Found!] Rallye Bezel Center Lens
DionR
Spokane, WA
Need a center lens for the Rallye cluster I just bought.
Not looking for perfection, just something that could be usable after cleanup.
Not sure if it matters, but the cluster is our of a '71 Duster.
Shipping would be to 99122, but I expect a small flat rate box should swallow it fine.
Thanks.
Not looking for perfection, just something that could be usable after cleanup.15.00to you
Thanks.
If you'll use a ink pen shaped solder iron to remove or reinstall these lenses... keep the thing upright. Lean it and its hot shank will scar a lens instantly. Yep been there done that.
Hmm....I hope the bezel I bought doesn’t have the locations to mount that lens destroyed. It has the gauges and such mounted so I haven’t looked to see yet.
This is the lens I have all the others to yes 15 shipped in us
You can use epoxy. Rough up the slick plastic so it gets a better tooth/bond.
So is there more to the lens than what I am thinking? After seeing the below picture, I am starting to think I am missing a cup for the lens as well???
Good grief. I never thought I was completely aware of how these dashes worked and went together, but I am starting to feel like a complete noob as I keep seeing stuff I missed or misunderstood.
If you need all the parts lens cups black center the other lenses metal cup 25.00to your door for all if you need photo I can get you one
Yes there should be a lens, cup and a metal ring.
I just need the rest of the stuff for the center lens. The cluster I bought has the other lens and supporting parts. I just didn't understand what all was missing for that center lens.
Pictures would be great.
Thanks!
Is the cup you are referring to the "button" on the front of the lens? And the metal ring is what I was calling the cup? Does that make up all three parts?
Based on the picture from badlilred79 for the part he has sent so far, that would mean I am only missing the metal ring to have a complete lens. Correct?
BTW, you probably already figured out that picture is yours. I was reading the "Gauntlet" thread looking to see how people had refinished their bezels when I saw your picture and realized I was still missing parts.
Lol, I never realized that was my pic. Yes the middle one has 3 pieces. I just dug out some spares I have. 1 put green tape on the 3 individual pieces. But I noticed some differences that I will explain after, I dont wanna confuse/mess things up.
Thanks, I'm in the same boat. Wanted to sell these but unsure how to properly label them
The middle one you want will look very similar to pics above, but I believe has 3 tabs total as it's a smaller lens instead of 4 like the pic above
Sorry for delay, I was doing night shift and was horizontal.
Thanks! That explains it very well.
So @badlilred79, looks like I just need the metal ring for the middle lens. How much for that piece shipped?
Appreciate all the help from both you guys.
I'll send you all the rest of the parts rings other lenses all the rest 20.00shipped
