Random Early A Body Questions
M52
1. Anyone make stripe kits for early a bodys ?
2. best fitting SB headers, any one make fenderwell headers?
3.any good place for fiberglass parts?
4. anyone make floor pans etc?
1.Try member ChallengerGary for any stripe kit
2.s.b headers from TTI or Doug,s
3. You could Google for #3 and 4 there,s a few different places for exterior panels.
Not sure about how their products are, but these guys have some fiberglass parts for them:
http://www.usbody.com/ShopOn-Line/
While I can understand wanting to get some room by cutting out the inner fenderwells, I do want to warn you to be cautious with that. While on a lot of Chevies, the inner fenders are just splash guards, on early A-bodies, the inner fenders are pretty much the equivalent of frame rails. Be careful how much metal you cut away, and whatever you do, don't leave sharp corners. I've seen a couple A-bodies with fenderwell headers that had enough metal cut away, or cut in the wrong places, to have visible alignment problems.
i hear that the F-Body front end stuff will work on the A-Body if so can anyone tell me if it will work on the early A-Body and is it hard to find the - the V8 center link for an early A-Body
Its easier to find conversion motor mounts which raise the engine enough that a V8 centerlink is not needed.
