1.Try member ChallengerGary for any stripe kit
2.s.b headers from TTI or Doug,s
3. You could Google for #3 and 4 there,s a few different places for exterior panels.
While I can understand wanting to get some room by cutting out the inner fenderwells, I do want to warn you to be cautious with that. While on a lot of Chevies, the inner fenders are just splash guards, on early A-bodies, the inner fenders are pretty much the equivalent of frame rails. Be careful how much metal you cut away, and whatever you do, don't leave sharp corners. I've seen a couple A-bodies with fenderwell headers that had enough metal cut away, or cut in the wrong places, to have visible alignment problems.
i hear that the F-Body front end stuff will work on the A-Body if so can anyone tell me if it will work on the early A-Body and is it hard to find the - the V8 center link for an early A-Body
