Rmoore
Has anyone cut the mains down on a rb 4.15 crankshaft 2.750 to a 2.625 b block ?
How costly was it to line bore the block to that sizeNot a 4.15 but I had a 400 block cut to the RB crank mains. Another way to skin a cat. Comes out to 451 cu.in.
I have a rb 500/ 440 stroker kit.I was thinking about turning the 4.15 crankshaft to fit the 400 b block 2.625
I’m guessing you realize you’ll have to use a shorter piston/rod comboI have a rb 500/ 440 stroker kit.I was thinking about turning the 4.15 crankshaft to fit the 400 b block 2.625
Yes I am aware !I’m guessing you realize you’ll have to use a shorter piston/rod combo
