gtxtra361
What does it take to put a 440 crank into a 400. And any down sides to doing so.
Thanks cliff
Thanks cliff
I did this to a 74 charger back in 07/08. It's pretty straight forward, a good shop can do it and balance everything for you. They essentially just grind the main journals to the smaller B series sizes. Now a days though, the prices on 440sources stroker kits make it more economical to just get one of their kits.What does it take to put a 440 crank into a 400. And any down sides to doing so.
Thanks cliff
Thanks for the responseI did this to a 74 charger back in 07/08. It's pretty straight forward, a good shop can do it and balance everything for you. They essentially just grind the main journals to the smaller B series sizes. Now a days though, the prices on 440sources stroker kits make it more economical to just get one of their kits.
As for clearances, it depends on the block, the later years(76-78) have thinner walls than other years but not by much. Mine didn't require any clearancing to be done but consult with your engine builder.
As for downsides, not many at all. A 451 (400 with a 440 crank) is gonna make good reliable and useable power especially torque.
No not even close. A 400 has a larger bore than a 440 @ 4.342 vs the 440's 4.32 bore. Putting the larger 3.75 inch crank in a 400 nets a minimum of a 445 if no over bore, an overbore of .030 Nets roughly 451 cubic inches.You essentially end up 426 C.I. but you have weak cast internals.
I called up a place called RPM international for mine. Told them what I was doing and they sent me a set out, it was roughly 350 buck for the set including ARP bolts. But that was ten years ago, I don't know what they charge now a daysThanks for the response
What rods do I need to use
Plus, you don't do this with a cast crank. 440s pre 73 had forged cranks, easily found these days
Building a low deck stroker with a 440 crank, and using 440 length rods completely defeats the purpose of building such a beast...just keep it simple and use the 440 block.
That combination using a B length rod is a whole different story.
By shortening up the ratio and increasing angularity, you're talking about a combination that literally pukes instant torque.
Thanks cliff
long rod is supposed to have better "wear" caracteristics.I built them with the long rod and short piston and the short rod with the taller piston. Really not much difference in overall performance. Kim
long rod is supposed to have better "wear" caracteristics. Bottomline>440-.030 over=446, why go to the trouble for 5 c.i., unless ur wanting a hair stronger block or need the room from the low deck.
Peak numbers are going to be about the same. The real difference is how the short rod engine will hit the converter.I built them with the long rod and short piston and the short rod with the taller piston. Really not much difference in overall performance. Kim
splain that to me. I`ve never had a problem hitting the convertor> LOLPeak numbers are going to be about the same. The real difference is how the short rod engine will hit the converter.
Back to back, the difference is pretty profound
A shorter rod sees greater angularity earlier, as measured in crankshaft degrees than a long rod, so it is pushing into the cranks rotation rather than down on it.splain that to me. I`ve never had a problem hitting the convertor> LOL
