i'm going to re-ring a 360 and had the pistons sitting on a piece of plywood. anyway, four of the pistons fell of the plywood so I don't know what hole they go in the block. how important is it to have them put in the original hole?
no i didn't I had them in order on the plywood, but I guess I should have marked them some how. the motor is standard bore. each rod is marked with a symbol, but not a numberYou didnt # the rods?
It actually is kinda important, and that is definetly a mistake. Ideally you are supposed to # the rods to the cylinders they come out of.
Actually it DOESN'T matter. What IS important is that you get the correct rod caps on the correct rods.
I would stick each piston in one hole, and measure clearance the same way on each to see if you can determine if any are worn substantially more/ less than the others.
If not, does not matter which hole
If so, mike the bores and try to match the larger pistons with the larger bores.
Again, MAIN thing is that the rod caps are on the correct rods.
X2
as long as they are the same weight, really don't matter where they go unless they have asymmetric valve pockets
