norshorblufish
By the Big Water
Get a big vat fill it when evapo-rust let it soak in it for a week or 2 take out slap it in the car and your good to go.
Probably cost more than a crate motorGet a big vat fill it when evapo-rust let it soak in it for a week or 2 take out slap it in the car and your good to go.
Does It has 340 stamped in the drivers side of the block. Because the info I have is conflicting with that#Working on the engine today. Lifters are out, another soaking, and I found a VIN! 8B121771, I’ll post it over in the lost and found too!
It has 340 cast into the casting number on the drivers side of the block. I could probably scrub off the pad under the drivers side head and find the numbers there too.Does It has 340 stamped in the drivers side of the block. Because the info I have is conflicting with that#
That# should have a P or H in itIt has 340 cast into the casting number on the drivers side of the block. I could probably scrub off the pad under the drivers side head and find the numbers there too.
here looking over your shoulder waiting on the next post brother
Oh how I wish I still worked at Stahl Manufacturing in the plating room. I had access to caustic soda ranks, phosphoric acid tanks, sulphuric acid tanks, cadmium plating, anodizing, phosphate plating. Oh, the things I could do now!Throw’er in the caustic soda hot tank, come like new.
Yup
