Realest's 1969 Dart Custom
The rotisserie works like a dream! This is much nicer to work on.
While you have it on the rotisserie would be a good time to install subframe connectors, instead of trying to weld overhead.
Yup! that is the plan. I can't weld worth a darn over head and out of position.
Figured it was time for an update.
I have switched gears a little and started sand blasting the underside of the chassis.
The results make me a happy man!
Continuing progress with sand blasting! The floors are cleaning up nice but there are still some minor holes to be repaired. A little metal work will required in the passenger inner kick panel.
Today I worked an finalizing mocking up the USCT spring relocate brackets. I hope to find time to weld in this week.
I've been making some progress welding and grinding the spring relocate brackets in emphasis on the grinding part. :realcrazy:
This weekend my dad and I made a trip across the boarder to pick up my shipment from AMD.:canada:
I've made some progress on my diy subframe connectors. 1 Down 1 to go, then the welding party begins.
I managed to get the sub frame connectors fully welded in, and started clean up on the penetration on the inside of the floor pan. I uncovered a thin area that I tried to initially weld up, but that wasn't an option. The area was too thin (+ my armature skills) causing the hole to get bigger. I eventually resorted to my first sheet metal patch which turned out okay. I still have a lot to learn when working with thin old metal. I have some holes to deal with, near the patch I installed, where the seat mount bracket is. That'll be a fun next adventure for me.
