Rear Axle or Gear Confusion
jonn6464
1970 Duster
Weatherford, TX
Hey FABO, sorry this is not specifically for an A Body but it's MOPAR nonetheless.
1975 Trailduster, 3.55 suregrip, 2WD.
I had the rear end off the ground working on the brakes. When I put the wheels back on, I noticed that I can move (turn) the wheels about 1/4" before the driveshaft yoke starts spinning. I can hear and feel it when the yoke starts to turn, it has a little bump then it starts moving. I can see directly through the wheel well to the yoke, so I can see exactly when it starts to turn.
Is this a symptom of bad bearings or something in the ring gear, or something else all together? Or, is that normal?
Thanks for any replies.
>If you're SureGrip is working, and it is a clutch-type, this may or may not NOT be normal.
> If your SureGrip is a Cone-Type, and working, this is probably normal.
> but if it is NOT a SureGrip, or it is a worn-out Cone-type, then;
What you are feeling is the pinion gears climbing up and down the cross-pin; and .25inch of wheel-travel is actually very good and nothing to worry about.
Ok great, thanks for the info.
It’s probably a 9 1/4 rear. Dodge had a shim kit to put on the spiders that go on each end of the pin in an open diff. I can’t remember if u replaced them with thicker ones or they were missing and u had to add them. But like said it’s probably normal wear for the mikes it has. I have seen the axle splines worn. Kim
