ajarofclay
Hey Gang, I've got a query. First off, I gotta say electronics are definitely not my forte though I'm getting a little more informed. That said, I put a rear window defroster in my car YEARS ago, I just tied it into the accessory fuse and put in my own toggle switch along with an Led light. In recent years I've been acquiring parts to get it closer to stock again so I picked up a used factory wiring loom. I'm trying to hook it up and I'm a bit miffed. I thought there was something possible missing put after some some searching, I think not. It is basically 2 parts. The long tail is hooked up and it will operate if I run a jumper from that to the hot side to the fuse box, but I can't figure out how to properly hook up the switch to get power. All the plugs are self explanatory but there is only one other loose wire which is just a green ground. There has to be some kind of lead to get power I would think?? I'm attaching a couple of pics of a loom. It is NOT MINE but it is exactly the same. ANYONE know what I'm missing. Sorry for being so long winded.
