vntned
So how much does swapping to rear discs effect the track width?!
Where is the 1/4" width from, longer distance from bearing to wheel mounting surface or flange thickness?A-body 5 x 4.5" bolt pattern conversion axles increase the track width 1/4" per side compared to the original 5 x 4" bolt pattern axles.
A typical rear rotor increases the track width an additional 1/8" per side compared to the thickness of a brake drum.
