Rear end options
PostalBGraham
Northwestern Pennsylvania
I am replacing my 273 with a 340/727 in my '67 Barracuda. I am having trouble locating an 8 3/4 rear end. I am told that some guys are using old Ford Ranger 8.84 rear ends. I have access to an F9 rear end, no housing or axles. Has anyone here used either of these Ford rear ends?
Yes, you can use a 9" ford, or an 8" also. I got a 72 mustang rearend and it bolted right in but had to use an adapter U-joint for the driveshaft. Even the e-brake cables worked. That rearend is about 2" overall wider though, so check your wheel spacing for that.
If it's a mild 340 an 8-1/4" out of a later A-body will work fine. It would be a more straight forward swap everthing considered. The ring gear diameter is not the only determining factor as to how strong a rear end is. It's the same rear end in my 81' D150 and 77' Cordoba with a 400.
I have been told the ford is a strong rear end, but it also takes some extra horse power to turn. more so than a 8 3/4 or 8 1/4. has any body else heard this?
I was also told that the 9" rear end was "heavy duty" and "indestructible". The 340 I'm putting in is bored .030 over with 10:1 compression. The intake manifold is an Edelbrock high rise with an Edelbrock 650cfm carb. I'm not sure what the gears are in the 9" rear end. I suppose that has a lot to do with whether or not the engine has enough horsepower to turn it.
Yes, the pinion is further below the center line of the ring gear than in the 8 3/4 or 8 1/4. This requires the gear teeth to be at more of an angle which increases friction.
