Badart
Senior Member
This motor hates me. My 318 has had a leaking rear main seal since rebuilding it and it seems to be getting worse. I know that it is the rear main because of all of the oil on my flex plate and convertor. At first it was just annoying and I thought that I could deal with it, but now it's starting to piss me off.
My plans are to pull the motor and fix it. My question is that I want to know is there any way of changing it without pulling the heads and pistons? I am thinking that If I pull the timing cover and remove the main caps I can lift the crank enough to change it. What do you think? Anyone ever try this. I don't want to spring for new head gaskets and take a chance with one of them leaking later or tear down the entire engine.
