That car would have most likely came with a 3.23 ratio
Not with the A904 - they got the 2.76 - 3 speeds got the 3.23 - I think you could get a couple other ratios in the suregrip version (3.55 and?)
Unless you know how to properly set up a gear set (pinion depth and drag, backlash, gear mesh pattern and the like) there is no "swapping out gears". in any rear end. You will need some special tools, equipment,parts, and know how.
