T56MaxTorq
If the thing is not firing evenly, then I would not rely on the AFR to tell me where the mixture is. Unburned fuel is not seen at all by the O2 sensor, but unused oxygen WILL be registered, and, as a result, your AFR readings look lean.
Too much lifter piston compression would sure cause the symptoms...... seems worth investigating.
As for the ICA, I suspect it is in the low 60's due to ground-in cam advance; that gives you cranking pressures like what you have.
Any exhaust restrictions going on OP? Like something got dropped down the turbo outlet pipe? Is the turbo spinning freely? I know it won't likely be spooling at idle but it ought to be free. That is one more exhaust restriction that is going to effect back pressure and effect cylinder clearing and filling.
Ya know, I did do a lot of oiling mods, opening up the ports and suction, reducing friction by blending the turns. That would deliver more local oil pressure at those lifters, especially the first in line. If all else fails I can reduce the preload by half and see what happens. Oil pressure with 10w30 is 75 cold idle, 30 hot idle.
No chance of exhaust restriction. When hooking up the down pipe, I needed to trim it by an inch to add firewall clearance so I pulled it, cut it, and welded it. It was clean, the muffler is also clean.
The turbo spins nicely at idle and you can really hear it draw in air, too. Even with the filter on. Sounds sinister (in a good way.) The average Joe must think my brakes are bad.
