Rebuilding a power steering pump. How difficult?
Ron Grubb
Member
Indiana
Power steering pump leaking Bad! Rebuild is difficult to get. Kits are no problem. Mine is the TRW pump. Suggestions? Thanks.
What's the worst. A few bucks and it still leaks!
Go for it.
My hardest part when I have taken a PS pump apart is getting the reservoir off.
If it's leaking but otherwise working it might be the big O ring and the seal round the output port
Could also have a crack in the metal reservoir
Agreed, if it's just a leaker and otherwise works ok, not a big deal. The hardest part is the pulley seal. You just need the correct puller for the pulley and a way of pressing it back on. do it with the reservoir off so you don't damage the reservoir or it's "O" ring. I use a cheap dent puller slide hammer with a screw attachment to remove the seal.
I believe the factory service manual covers it.
