Hyper Henry
This was a very low mile 1970 Big Block Chrysler 440 that was just completely rebuilt.
fresh cross hatched cylinders and surface decked
brass frost plugs, pipe plugs and dist. bushing-new
steel crank polished
Clevite main & rod bearings (standard)-new
ARP main & rod bolts-new
OEM pistons (9.5 comp.) with Speed Pro rings-new
Milodon 7 qt. oil pan, pickup and windage tray
Melling High Volume oil pump-new
Comp Cams solid mechanical camshaft and lifters, .520/.540 lift, 244/252 dur., 110 LS (cam had been degreed)
Comp Cams true roller timing chain
906 heads, lightly ported and gasket matched, 2.08 stainless valves, hardened seats with Indy valve springs (good to .600 lift)
Comp Cams chrome moly .080 pushrods-new
1.5 Roller Rockers-new
ARP head bolts-new
Felpro head gaskets, engine gaskets and valley pan-new
Mopar Performance M1 intake
Edelbrock valve covers-new
Motor is fresh from machine shop ready to drop in. asking $3300...much more than that invested!! Carb does not go with motor. Can ship anywhere at your cost but very fair rates.
Located in Kitchener, Ontario, Canada.
ARP head bolts-new
