redneck tools for the hobbyist
Cut the gear off an indeterminate shaft, weld a push rod to it.
Cheap oil prime tool.
Most everybody has the extra parts laying around to make it.
1/4"broken extension.machined female end to 3/8" and threaded it to 3/8 fine. Cut rest off and threaded it into a small drill chuck. 1/4" air ratchet is now a slow speed angle drill.
I found a bolt that fits the hole saw,drilled 1/4" pilot through it. Place hole saw exactly where i want, run drill bit and pilot the hole.
Same bolt and a 3/8" air ratchet may get a hole in a tight area.
I got a million of em. Stay tuned.
So i cant always use my shop, my storage building is the next best thing. No lights though. Came up with portable lights that i feel will suit me very well.barracuda is in line right behind this junker...
Well, welded these up day before yesterday...and just today painted my newly built Toe Gauge Bar......
So greasing is a pain,add nitrile gloves and bad grip, you need a locknlube. Ya, cant get that here. Use this.a simple 3/8" washer.
