Robj
As long as I've got my dash apart I'm replacing my wiper pivot seals. The jute on the underside of the dash is hanging loose in some spots and is hanging on the wiper linkage in a few areas. It's still in very good condition.
What would some of you recommend as an adhesive to reattach the loose spots to the underside of the dash without removing everything?
I'd rather not use a spray adhesive and get sticky overspray on everything under there. Not sure if contact cement would work. Thinking of something thick that can be brushed on or shot on with a caulking gun. Ideas would be appreciated. Thanks!
