Reference points
Mopar87
Lewiston,Id
So I know how notorious our cars are for not being square.Are their any points underneath the car that are square and straight enough to cross measure to locate and square up the suspension?
I dropped a plumb bob off the torsion bar cross member sockets, centered the string on the socket itself. Car needs to be level. For the rear end I did the same off the hub then measured front to back each side and Cross ways lt to rt and rt to lt. My purpose was to position the rear housing before welding spring perches on. If that makes sense. Hope it helps. When I had it aligned, guy said it was pretty square on the rack. I’d asked him to check. Whatever that’s worth.
The points are detailed in the Factory Service Manual
If you just want it to track straight, any computerized 4-wheel alignment rack can tell you how far out it is..... in a couple of minutes. Then it could take all day or more to straighten it out.
or not,lol
I have to pull the front end apart and fix and reinforce all of the broken front suspension mounts at the very least or I might swap in an entirely different front suspension from a dakota.So after its sitting level on jackstands I am going to measure 9000 times before I unbolt anything or attempt surgery.Then while I am at it I will square up the rear suspension as well.So its sounding like the torsion bar crossmember is the only thing under there that I can square the suspension to, is that correct?
There are Multiple diagonal measurements for body alignment, wheelbase checks, rear end centering,and lower BJ location.
The front and rear stub frames are welded in so if the "frame" is tweaked, you can't do much about it except compensate by moving the suspension pick-up points.
As to the front;
The 4-wheel alignment will reveal your Thrust angle, and then you can decide what to do about that, if anything.
The front suspension is built around where the lower BJs end up, so it's kindof important to have them correctly located.
Make sure the front frame rails are in good shape, and that the aprons are well secured, especially at the firewall . The cavity below the Upper A-frame mounts, tend to collect debris and water, and so they end up thin and or holed. You can't have those mounts moving around. The aprons also tend to separate from the upper shock mount. The rear part of the front rails also collect junk and water between it and the floor, and the T-bar sockets occasionally rip out. I guess it would Sux to be you if that happens at speed; I've seen the damage that occurs when that happens just sitting in your driveway.
As to the rear;
You can correct the rear axle alignment if/when you move the springs inboard. The rear spring mounts tend to break out, dropping that corner.
Your rockers on a unibody are structural, and until you install frame connectors, must be in good shape.
Other
The cowl needs an inspection as well, cuz they also collect debris and water, and when they rust out, you get a foot-bath in the rain, and your feet freeze in winter. Water entering from there collects under the carpet in the footwells..... so if your footwells are holed, probably so is the cowl, or the base of the windshield.
On fastback/sportback models, the bottom corners of the rear windows often allow water penetration there, which ends up in the pockets between the rear quarters and the trunk extensions, spelling their death.
The core-support is structural and keeps the front ends of the frame members properly located. and therefore your suspension located. That whole front tub is one large structure and needs to be as good as immovable.
That's all I can think of.
